cathdes8
Apr 16, 2026 4:04 PM UTC
Critical Issue with Exporting Figma Slides
After the recent update, a critical bug has appeared: it is no longer possible to export Figma Slides to JPEG/PNG in bulk. Images are missing, and presentations are exported without them.
Our company uses a paid version of Figma, and unfortunately this issue occurs across all plans. We work with large presentations (30 to 100+ slides), and we are now forced to export each slide individually.
This is significantly impacting our delivery timelines and overall workflow efficiency. Please address this issue as soon as possible.
It is extremely frustrating to repeatedly explain that the only tool capable of handling these tasks is currently malfunctioning.
We expect a prompt resolution.
Celyn_L
Apr 17, 2026 7:34 AM UTC
Hi ​@cathdes8, Celyn from Figma Community Support here. Thanks for taking the time to share this in detail.
I understand that you’re running into an issue with bulk exporting Figma Slides to JPEG/PNG, where images are missing from the exports. I can see how this would make it much harder to efficiently handle larger presentations, and I’d like to help you look into this.
To help narrow this down, could you confirm a couple of things:
  • Are the missing images happening across all Slides files, or only specific ones?
  • Does this happen when exporting as PDF as well, or only JPEG/PNG?
As a quick check, you could also try exporting from the browser vs the Desktop app (or vice versa).
In the meantime, I’ve gone ahead and created a support ticket (#1854643) so the team can take a closer look.
It would be really helpful if you could reply to the ticket with a direct link to the impacted file, and invite support-share@figma.com with “Can View” access (this won’t impact your billing and will allow us to reproduce the issue and investigate with Engineering).
Appreciate your patience here - we know this is impacting your workflow, and we’ll work to get this resolved as quickly as possible.
