H4RK4N
Jan 20, 2026 5:31 PM UTC
CRITICAL ISSUE
Hi everyone,
I urgently need help because my website built with Figma Make has become completely unusable. It previously worked normally with:
  • a public site
  • a multi-user login system
  • a private staff-only dashboard (internal mission/task management)
  • an admin account to manage everything
Now everything is broken:
  • I cannot log in anymore (including my admin account)
  • the staff dashboard is inaccessible
  • key features that used to work are down, so this is blocking our work completely
The console repeatedly shows (Project ID masked):
❌ Failed to load config TypeError: Failed to fetch ❌ Error fetching profile: TypeError: Failed to fetch ❌ Error fetching stats: TypeError: Failed to fetch ❌ [Supabase] Http: connection closed before message completed at async Object.respondWith (ext:runtime/01_http.js:338:15) ...
I’ve attempted to fix this many times (20+ attempts) using Figma Make’s AI “fix” suggestions, but the errors remain the same and the site does not recover. I don’t have coding knowledge, so I’m stuck.
What I suspect:
It looks like the app can’t fetch its runtime config anymore (“Failed to load config”), and then all Supabase requests fail afterwards.
What I’m asking:
  1. What are the most common causes of “Failed to load config / Failed to fetch” in Figma Make projects? (routing/rewrites? preview hosting? CORS? env/config missing?)
  2. What are the best next debugging steps to confirm the cause (Network tab checks, specific settings to verify)?
  3. If someone from the Figma team can help, this is time-sensitive because we’re locked out of admin and staff tools.
I can share Figma Make project access privately (DM) with a team member/support so you can inspect it directly. I will not post any secrets publicly (keys/tokens).
Thank you — any help ASAP would be appreciated.
Celyn_L
Jan 21, 2026 8:02 AM UTC
Hi ​@H4RK4N — Celyn from Figma Community Support here.
Thanks for flagging this and for sharing detailed context. I’m sorry you’re running into issues with your website built with Figma Make, and we’d love to help get this sorted out as quickly as possible.
The “Failed to load config / Failed to fetch” error can occur when the app is unable to make a request to the required endpoint.
To help move this forward quickly, I’ve gone ahead and created a support ticket for you: #1699388. I can also see that someone from our Technical Quality team has already reached out — please check your inbox when you have a moment.
Thanks for your patience — we appreciate you working with us as we get this resolved.
