MNCreations
Jul 1, 2025 12:22 PM UTC
Create isntance swap window closes when hit create property
I am trying to create an instance swap on Figma on my iPad (in browser) I’ve tried several browsers and the behaviour is always the same. I select the piece of the component I want to instance swap (a chevron pointing down) and select the create instance swap property button. The popup appears and I can name or switch the instance but when I click to add a preferred instance to swap with the window closes with nothing having happened. The same is true when I click “Create Property” closes with nothing having happened. I also tried creating the property from the top level component and a similar issue occurs. I can name the property but when I click the “Pick an instance” button, the menu opens to pick one but clicking a component to use as an instance just closes the menu without having done anything. And you can’t create the property from this window without having picked an instance first. The instances I want to be able to swap are made from two chevron components.
