gouveiamiddough334
Nov 30, 2026 9:44 AM UTC
Could not start dev server — server errors detected on publish
Hi, I'm running into two related issues when trying to work on my scenario/app: 1. The dev server cannot be started. I keep getting the error: "Could not start dev server." 2. When I try to publish, the system shows: "Server errors detected. Your Make has errors in its server logs. Ask the agent to fix this for you then try again." I have already tried the "Fix for me" option, but the problem still persists. Could you please help check the server logs and let me know: - What is causing the dev server to fail? - Is it related to a connection, authorization, or a module configuration? - What steps should I take to fix it and publish successfully? Happy to share the execution history / screenshots of the error details if needed. Thank you.
