Rujen
Aug 8, 2026 9:52 AM UTC
Copy & Paste frames are not working in Figma Make
I'm looking for help with an issue that has been affecting me for quite a while.
My workplace provides me with a Figma Professional plan, but I have been unable to directly copy and paste any frame into Figma Make. Every time I try, I receive the following error message:
"Something went wrong. Try different frame or try again."
Issue details:
  • Number of frames attached: Even a single frame cannot be copied/pasted
  • Error message: "Something went wrong. Try different frame or try again.
  • Environment: Occurs in both the Figma Desktop App and web browser
  • Duration: This has been happening for a quite long time now
  • Scope: The issue is not limited to me. Several of my coworkers are experiencing the same problem
I've already tried refreshing and retrying multiple times, but the problem persists.
If anyone has encountered this issue before or has suggestions, workarounds, or insights into what might be causing it, I would greatly appreciate your help.
Thank you!
Tom Reem
Aug 8, 2026 7:36 PM UTC
Hi ​@Rujen — welcome to Figma Forum, and thanks for laying this out so clearly.
I tried reproducing it just now: copied a frame from a Design file into a Make file, prompted it to change the color palette, and it worked as expected. I’d like to find out if what's happening is specific to your setup or your designs. I you’re up for it, please reply with some more details and I’ll keep chasing this down.
Could you walk me through your exact steps? Things that would help:
  • Where you're copying from, and how (Cmd/Ctrl+C on canvas, or right-click → Copy?)
  • Where you're pasting (the prompt box in a new Make file, or an existing one)?
  • What's in the frame (is it content-heavy, lots of images or vector illustrations, or does it use components from a shared library)?
  • Whether it's every source design file (or just certain ones)?
  • Also, I know you said it’s been a while, though do you and your team recall a more specific timeframe when it started?
With that, I can try to reproduce it on my end, then escalate. If I can't, the next step is a Customer Support request with a short screen recording and the file shared to support-share@figma.com with view access.
Thanks for your collaboration on this — looking forward to your reply.
Rujen
RujenAuthor
Aug 9, 2026 4:41 AM UTC
Hi ​@Tom Reem
Thanks for looking into this.
Here are some additional details:
  • I'm typically copying the frame directly from the design canvas using Cmd/Ctrl+C and then pasting it into the prompt box of a new Make file.
  • I've also tried pasting into existing Make files, but the result is the same.
  • The frames are generally not very heavy or complex. They don't contain a large number of images or vector illustrations, but they do use components from a shared library.
  • From what I've observed, the issue doesn't appear to be limited to a specific workflow, as I consistently get the same error when attempting to paste frames into Make.
  • As for timing, I would estimate that this started around 3–4 weeks ago. Several of my coworkers have been experiencing the same issue during that period as well.
Please let me know if there are any other details that would help with reproducing the issue. I appreciate your help in investigating this.
Thanks!
Tom Reem
Aug 9, 2026 7:51 PM UTC
Hey again ​@Rujen — this is really helpful, thank you.
The library components detail is interesting to me, but I want to be careful as it doesn't appear to be a limitation. I would like to understand if it makes a difference in what you're seeing though. Could you try this? 👉🏻 Duplicate one of the frames that's failing, detach the instances in the copy (right-click → Detach instance), and paste that into Make. If the detached copy attaches fine while the original doesn't, that's a clue and gives our team something concrete to chase.
The mid-July timing and the fact that your coworkers are all affected is useful too — that pattern points to something worth reviewing internally.
Either way, I'll go ahead and submit a request with the Customer Support team now rather than wait. If you can check your inbox for a message from me associated with case number: 2061460, and include a short recording, the error ID (if possible) and a file where this is happening, it'll help us investigate further.
Tom Reem
Aug 16, 2026 11:17 PM UTC
Checking back in with you ​@Rujen — the email I sent didn't reach you, so I'll follow up here instead.
Two quick things:
  1. Are you still running into this? And did the detach test change anything (pasting a copy of the frame with its instances detached)?
  2. To get the file in front of us, please submit it through the Support Hub and share the affected file with support-share@figma.com with view access. If you can reference your case: 2061460, that'll track back to what we've already logged.
Thanks again for sticking with this.
