Charles Gallant
Apr 9, 2026 10:59 PM UTC
Converting a Group to a Frame is broken?
When editing a master component, using the UI pulldown menu (right sidebar inspector) to convert a Group to a Frame updates the layer display, but the underlying Plugin API node type incorrectly remains GROUP instead of changing to FRAME.
The issue here is that there’s now a mismatch between the way the API can access this node type and the way it’s represented to humans in the display tree; Humans can’t visually verify that we’re looking at a false Frame (that’s really just a Group) unless they run dev console commands against the node type.
Steps to reproduce:
  1. Create a Component
  2. Add random things to it, Group those items
  3. Select the Group
  4. Type this in the console:
    1. console.log(figma.currentPage.selection[0]?.type);
    2. ​​​​​​Note that it says “GROUP”
  5. Use the UI to switch in the sidebar to change it into a Frame
  6. Repeat the console command
  7. Note that it still outputs “GROUP”, and display tree says that it’s a Frame
