Martin Fabricius
Sep 9, 2026 7:31 AM UTC
Connected folders
Hi,
We are having trouble with connected folders.
Setup:
  • We are on Enterprise and we host the connected folder
  • The connected folder is shared with our client's product team
  • The client is on an Organization plan with paid Full and Dev seats
What happens: when the client's users join the connected folder, a guest seat is created for them in our organization. When their developers then use the Figma MCP server, they hit a rate limit almost immediately and get a 429 response.
Our reading of it is that the rate limit is being calculated from their guest seat in our organization rather than from the paid seat they hold in their own plan.
Questions:
  1. Why does joining a connected folder create a guest seat in the host organization at all, when the documentation says each party works based on the seat they hold in their own plan and the host is not billed for external users?
  2. When an external user works in a connected folder owned by the host, which plan and which seat determine their MCP and REST API rate limits?
  3. What is the correct setup so their paid Dev and Full seats are the ones being counted?
Happy to provide the folder link, the affected email addresses and the full 429 response headers.
Martin
Tom Reem
Sep 9, 2026 8:27 PM UTC
Hi ​@Martin Fabricius, welcome to Figma Forum and thanks for laying this out — these are great questions!
On the Organization plan (your client's) a Dev or Full seat gets up to 200 tool calls per day and 15 per minute, while a View or Collab seat gets up to 6 per month on any paid plan. The full table is here: Rate limits & access — worth comparing against what the developers are seeing.
How connected folders and MCP rate limits interact specifically for your setup depends on the actual seat assignments on that folder. To make sure we have this clarified, this is going to need a look at your account and folder settings.
As for your questions:
    Outside users show up as guests when they join a connected folder — that part is expected. Seats determine which Figma products someone can access, while edit and view permissions are set per file. A deeper look into your folder settings will help clarify specifics, though this guide holds more details: Guide to connected folders → How seats work in connected folders.
    MCP limits are set by plan and seat type. For connected folders, the guide states that people work based on the seat they have in their own plan or organization. If that doesn't match up with what you're experiencing, it will be best to get this in front of the Customer Support team so they can look at what's actually being applied.
    There are a couple of routes here: Guide to connected folders → Guests and external users in connected folders. If the invited user belongs to the connected organization (in your case, the client's) they join the folder using the seat type they already have there. If they're from a different external organization, they join your organization as a guest with a View seat by default, and any upgrade request is routed to a host organization admin. From what I understand from your post, your client's product team already falls into the first case, since they hold paid Full and Dev seats in their own organization. So this looks less like a setup change on your side and more like a question of what's actually being applied on the folder.
Since this turns on specifics we can't see from this public thread, it's worth gathering the following before you get in touch with Customer Support:
  • What seat each affected developer holds in their own organization
  • What seat, if any, they hold in yours
  • How each of them was added to the connected folder
  • Which folder the files they're hitting currently sit in
With that information, please get in touch directly and share those details securely via the Support Hub.
Know there’s a lot of moving parts here — keep me posted if anything else comes up.
Martin Fabricius
Sep 11, 2026 7:34 AM UTC
Thanks a lot for the reply, Tom. Looks like we have followed the guidelines correctly, so I’ve tried to contact the support team and I’m awaiting their reply.
Thanks again
Gayani_S
Sep 11, 2026 2:41 PM UTC
Hey ​@Martin Fabricius, I’m stepping in on behalf of ​@Tom Reem to help here.
There's nothing action needed we need from you right now, you're all set. Ticket #2123618 is in our queue, and while our team is working through a higher number of requests than usual at the moment, someone will be in touch soon to dig into the seat and rate limit specifics on your connected folder setup.
Thank you for your patience in the meantime!
