Pranay Gupta
Oct 2, 2025 2:00 PM UTC
Confusing sizing behavior with nested Hug and Fill in Auto Layout
Hi everyone, I’m running into some confusing behavior with Auto Layout sizing when using nested Hug and Fill settings, and I’d love some clarity on whether this is expected.
Here’s the setup:
  • I have a parent frame with its width set to 100 and its width sizing set to Hug.
  • Inside it, there are three child nodes: two text nodes and one frame node.
  • The two text nodes are set to Fill, and the frame node is set to Hug.
Now, here’s where it gets strange:
  • When I change the frame node from Hug to Fill, the entire element’s width increases to match the width of the longest text node. This seems unexpected, because the parent frame already has a defined width of 100 and is set to Hug, so I would think that should take priority.
  • Even more confusing, if I set one of the smaller text nodes from Fill to Hug, the overall width decreases — it looks like that takes precedence over the fill sizing, which doesn’t fully make sense to me.
Is this the expected behavior? And if so, how does Figma decide which sizing mode “wins” in a case like this? Would really appreciate a clear explanation of how Hug and Fill interact when nested like this.
gdrive video of the issue
Apolline
ApollineSolution
Oct 2, 2025 2:27 PM UTC
The parent frame isnt “set” to 100, its width is 100 because one of the children width is 100 (I assume both of the frames inside that node frame, they also interact with everything else in your auto layout)
Since nothing has a set width, everything will change when you touch the hug/fill parameters : hug will hug the text, fill will take the largest possible width in your case
Apolline
ApollineSolution
