Melanie_Bosch
Feb 9, 2026 12:26 PM UTC
Components are not updating
I sometimes experience issues where components don't update.
And there isn't any visible update possible anymore, not in the assets or directly through the icon on the component.
The only solution that works is using "reset to default," but this is frustrating since I've already set properties and other configurations. Is there a reason for this, or is there another way to trigger the update?
Thanks!
fembotka
Apr 21, 2026 9:44 AM UTC
same here, selected components ae properly linked, but they are not updated. Even pasting the last component from the librabry to the design file doesn’t help and they reverse their changes
Dorothy Toth
Jun 1, 2026 4:35 PM UTC
same problem here. It seems like a relatively new issue?? among other Figma updates related to AI??
Jun 2, 2026 9:56 AM UTC
Hey everyone, thanks for reporting this! Just to better understand what's happening, is this occurring with a specific library or across multiple libraries?
Also, when the issue happens, can you confirm whether you're working from the latest published version of the library? If not, try publishing the latest changes and then updating the library in the affected file.
Since one of you mentioned that Reset to default resolves the issue, it's also worth checking whether the affected instances have overrides that may be preventing component updates from appearing as expected.
If the problem persists, please submit a bug report to our Technical Quality team so they can investigate further: Go to the Support Hub / Type “Report a bug” / Click Start a chat / Select Enter and follow the prompts.
In the form, please include: a screen recording, links to both the library file and affected file and grant Can View access to support-share@figma.com.
This will help the team reproduce the issue and investigate further. Thanks!
Heather Tompkins
Jul 24, 2026 12:08 AM UTC
Also having this problem a lot recently. Instances of my local components won’t update, even if I reset them to default, the changes just don’t get reflected. I’ve tried repairing them, I’ve tried reloading the file, nothing seems to fix the connection. Help!
Jul 24, 2026 10:56 AM UTC
Hey ​@Heather Tompkins , thanks for following up! It's good to hear you've already tried repairing the instances, reloading the file, and resetting them to their defaults.
If you're still seeing the same behavior after those steps, I'd recommend submitting a bug report so our team can take a closer look.
As mentioned above, go to the Support Hub / Type “Report a bug” / Click Start a chat / Select Enter and follow the prompts.
They'll be able to investigate what's causing the instances not to update correctly, thank you!
