Chelsea_Christison
Oct 28, 2025 9:18 PM UTC
Component Variables Not Updating
I have several component with linked Variables to the selected Theme on the page.
Even if I have the linked variables matched to the selected themes there seems to be a bug where sometimes the linked variable will not update to the proper theme when I switch the page level theme.
Some of the components update fine, others will not. I’m not sure what causes this but it’s confusing and frustrating.
Chelsea_Christison
Oct 28, 2025 9:20 PM UTC
I figured out my own problem.
Under Appearance, I had added a variable mode to my dark mode components. So they stayed dark mode when I set the page to light mode. I removed that and the component will now update to the correct theme.
Chelsea_Christison
Chelsea_ChristisonAuthorSolution
Tom Reem
Oct 29, 2025 1:14 AM UTC
Hey ​@Chelsea_Christison — thanks so much for circling back and sharing your solution! 🎯
I’ve gone ahead and marked your reply as the best answer so others running into the same issue can easily find it. Really appreciate you taking the time to follow up and help the community out
