Levi_Jones
May 2, 2021 3:25 AM UTC
Component Overrides don't apply to variants
Anytime I use a variant with overrides applied the interactive component causes the variant to revert to its default state in the prototype.
I may be doing something wrong, but it feels like a bug.
SomethingFishy
Apr 22, 2025 10:33 PM UTC
I should be shocked that this is still a thing…and yet I’m not shocked.
Definitely an issue.
What I’m doing and the result I’m expecting:
  • I add an instance of my component with hover state interaction to my file.
  • I change the color of that instance.
  • I run the prototype and my component (which is blue) now shows the override color (orange) on the default AND hover states.
What’s actually happening:
  • The component shows the override color (orange) on the default state plus elements common to both states, but NOT on the elements that are changing with hover (for example: a changing icon.)
One thing I have learned about Figma: the thing you expect to happen is never the thing that actually happens, and you can never tell if it’s a bug or not.
Figma is lipstick on a broken box layout where component interactions dissolve on contact with other pages.
Madory
May 17, 2025 3:43 PM UTC
I may have a solution:
I removed the accents, apostrophes, etc. from my variant names, published the library, and the bug disappeared.
Then I renamed my variants with the accents, etc. just to see..., published the library and it continued to work.
James_McLain1
Jul 28, 2025 6:02 PM UTC
I’ve literally been trying to fix this issue all day.
