leelee_design
Feb 11, 2026 9:33 PM UTC
CMS content not loading when clicking through from CMS list
I’ve created a simple CMS collection and added a CMS list to my site’s homepage. When clicking into either of the CMS items (labeled case studies), the page loads but none of the CMS content. I have to manually refresh the page and only then content loads. When I inspect the page, the content is there, it’s just not being displayed.
Furthermore when a user is on a CMS item page, and attempts to click the logo in the nav bar to access the homepage, the CMS list that loads only displays a single item listing (which doesn't retain styling , nor imagery). Can someone help figure out how to resolve?
rbz
rbzSolution
Mar 6, 2026 8:30 PM UTC
Hey all, sorry for the disruption here. We just pushed a fix for this. Could you try to republish your site and let us know if you’re still encountering this issue?
Robbie
Celyn_L
Feb 19, 2026 9:07 AM UTC
Hi everyone,
Thank you for your patience while we worked on a fix.
Our Engineering team has deployed a resolution and confirmed that the issue should be resolved.
Please restart or refresh Figma to ensure you’re on the latest version, and let us know if you continue to experience any issues.
We appreciate you flagging this and for your patience throughout!
Magdi19
Mar 2, 2026 8:21 PM UTC
Hello!
I have just experienced the same issue. Unfortunately it is still not working on my figma sites page, can you help please? Thank you!
​@Celyn_L
Hugo C.
Mar 2, 2026 10:54 PM UTC
Hello, same here, still experiencing the issue.
Tina25
Mar 3, 2026 8:00 AM UTC
Example website: https://sleeve-washi-79658529.figma.site/article/how-to-build-a-climate-ready-data-stack
I tried to use a Figma Site CMS template, and there are some problems about URLs and CMS data.
In this template at “article” page, I tried to link to other articles at the “Recent articles” section.
I found that in published mode, when linking to other article, the URL would change, but the content didn’t change with the URL.
And I have checked those data have already connected to CMS data.
published mode
CMS data connected
But at Figma design mode, when change the URL from the drop-down menu, the data will change.
design mode
Is this a bug or there are something I am missing?
[Moderator note: This post was merged from “Figma Site CMS URL and data connect” into "CMS content not loading when clicking through from CMS list" on 5-Mar-2026.]
Celyn_L
Mar 3, 2026 9:56 AM UTC
Hi ​@Magdi19 , ​@Hugo C. — thanks so much for flagging this. I’m sorry to hear you’re both running into issues with your CMS pages as well.
We’d like to take a closer look at what’s happening on the backend. I’ve created support tickets for each of you so our Technical Quality team can investigate and follow up directly:
  • ​@Magdi19 — ticket #1774050
  • ​@Hugo C. — ticket #1774057
Please check the inbox associated with your Figma account and reply directly to that email with the following:
  • A screen recording showing the behavior end-to-end, with the full Figma window visible
Additionally, please share the impacted file with support-share@figma.com and grant “Can View” access — this will not impact your billing and will allow us to reproduce the issue and investigate further with Engineering.
I’ll share an update here as soon as I hear back from the team — appreciate your patience in the meanwhile!
행복나눔재단
Mar 4, 2026 8:36 AM UTC
Mihajlo Kovačević
Mar 4, 2026 8:56 AM UTC
Now I have the same issue again!
The same issue occurred 20 days ago, it was resolved, but now it has happened again.
Christophe Bouvier
Mar 4, 2026 12:52 PM UTC
So I’m making a website for a company and we went with Figma sites because the CMS capabilities were added.
Now I got everything working on my end → Made cms collections → made detail pages that are linked to the fields in these collections + I made a list that also fill from the cms.
Everything looks ok in Figma sites design view, I can switch to the different collections detail pages and get a preview. Everything looks filled in and the slugs look good.
Now when I run the site within figma sites as preview or even if I publish the site. Then only the first item I choose from a collection list will load the correct page content. After that if I change to another cms page from the same cms list, I only see the same content which is wrong. What’s weird is that the slug is ok and I get the right content when I reload manually.
(Hard reset, clear cache and figma relaunch / reload have no effect → the problem just picks up again after that refresh)
(Also removing the collections and rebinding everything gives me the same results)
This is not very end user friendly. Any solution for this or fixes?
Kind regards
Christophe Bouvier
[Moderator note: This post was merged from “Figma sites CMS needs a reload to show correct content when you click through the list a second time” into "CMS content not loading when clicking through from CMS list" on 5-Mar-2026.]
Christophe Bouvier
Mar 4, 2026 3:33 PM UTC
I’m encountering the same problem. I described the issue here:
Any feedback if there will ba a fix available soon?
kind regards
Christophe Bouvier
Tina25
Mar 5, 2026 7:08 AM UTC
I have the same issue here.
I tried many times and it still not work.
Here are some notes and screenshots in my post.
Waiting for update and news to solve this issue.
Thanks.
