Adrian Martel
Aug 3, 2026 3:44 PM UTC
Cloudflare 1000 error when publishing a Figma Site to a custom domain
Hi,
We have been working towards using Figma Sites to publish, for the first time in our company, an external-facing website. It is to support our advertising proposition and can be found at ads.justeattakeaway.com.
However at that url we are seeing a Cloudflare Error 1000 error message.
Our internal technical teams are telling us that the Cloudflare issue isn't on our side because we have already set our proxy status for this domain to DNS Only (grey cloud).
Cloudflare's official documentation (at this page https://developers.cloudflare.com/support/troubleshooting/http-status-codes/cloudflare-1xxx-errors/error-1000/) says, of the error message we're getting, "Your DNS record points to a SaaS provider that uses Cloudflare for SaaS with BYOIP (Bring Your Own IP). Because the provider's IP addresses are advertised through Cloudflare's network, requests resolve to Cloudflare infrastructure. If the provider has not configured a custom hostname for your domain, this error is returned."
And the resolution they prescribe is:
"If your domain points to a SaaS provider that uses Cloudflare, contact the SaaS provider to verify that a custom hostname is properly configured for your domain. The error originates from the provider's Cloudflare account, not yours."
Can you help please?
Thanks 🙏
Adrian Martel
Aug 20, 2026 8:56 AM UTC
Hi ​@Celine_ , I'm delighted to tell you that following the information from your tech team we have now been able to resolve the issue that blocked our website from activating, and we are now live. Thank you for your support. I've closed this ticket 🙏
Aug 4, 2026 10:58 AM UTC
Hey there! Celine from the Community Support team at Figma here. Thanks for the detailed report and for including the additional context from Cloudflare.
As a first step, I'd recommend reviewing this Help Center article, which walks through the requirements for configuring a custom domain with Figma Sites: Manage a custom domain for your site.
If you're still running into the issue after checking those steps, it looks like this may require a closer investigation. In that case, please submit a bug report through the Support Hub: Go to the Support Hub / Type “Report a bug, contact agent” / Click Start a chat and select Enter and follow the prompts.
When you submit the report, please include the details you've shared here and these details:
  • The URL of the affected Figma Site.
  • The custom domain you're trying to use (ads.justeattakeaway.com).
  • Confirmation that your DNS records are currently set to DNS only (not proxied).
  • A screenshot of your current DNS configuration (if you're able to share it).
  • Any additional details from your IT team that may help with reproducing the issue.
Our team will review the configuration and investigate whether there's anything on the Figma Sites side that needs attention. Thanks for your patience!
Adrian Martel
Aug 5, 2026 9:09 AM UTC
Thanks Celine. I went through the diagnostic steps with your customer support, but it didn’t resolve the issue, so I’ve raised a bug ticket (number 2052503).
Aug 5, 2026 10:04 AM UTC
Thanks for letting me know! I’ve added a follow up note to your support case to increase visibility. Thanks for your patience!
Adrian Martel
Aug 17, 2026 10:35 AM UTC
Hi ​@Celine_ Do you have any idea when my support case may be attended to?
Thanks 🙏
Aug 17, 2026 11:09 AM UTC
Hey Adrian, thank you for following up here! We apologize for the delay, our support team is currently experiencing a higher volume of inquiries than usual, which is impacting response times.
I checked internally and can confirm your case has been received. I've added a follow-up note and escalated it internally to increase visibility. There's no need to submit another request in the meantime. The team will follow up with you directly through your existing case as soon as possible, thanks for your patience!
Update: The Technical Quality team has replied to you and is waiting for your response for the next steps. (Please note that it seems that Cloudflare is reporting that the custom hostname is currently blocked because the domain is associated with a held zone.) Please check your inbox for further details and continue the conversation directly there for further assistance, thank you!
Adrian Martel
Aug 18, 2026 1:54 PM UTC
Thank you ​@Celine_  - I’ve seen their message and am investigating on our side.
Adrian Martel
Adrian MartelAuthorSolution
Aug 20, 2026 9:41 AM UTC
Great, thanks for letting me know! I am glad you were able to resolve the issue 🙌🏼
I’ll go ahead and close the Forum topic here as well!
