Bruno31
Mar 12, 2025 11:53 AM UTC
Changing variable mode in Playground doesn't changes fonts
Hey there,
I’m looking into a component in DevMode and I noticed that when opening the playground, if I change the variable mode, the fonts aren’t changing, like the colors for example.
In design mode, by changing the variable it all works just fine.
Is this a known issue, are there any solutions…?
Thank you!
Mar 13, 2025 5:47 AM UTC
Hi ​@Bruno31,
Thanks for reaching out. I tested it on my end, and it appears to be working as expected (see below).
If I'm misunderstanding the issue, could you please share a screen recording of what you're experiencing or provide a little bit more details so we can investigate further?
Thanks!
Toku
Bruno31
Bruno31Author
Mar 13, 2025 9:45 AM UTC
This is strange,
Is exactly that what I want to do, and I made a sample like you have and it works, however in my main file (sorry can’t share a video) doesn’t work and is set up the exact same way… Otherwise the variable mode wouldn’t work in Design mode, but only in Dev Mode it has issues
Bruno31
Bruno31Author
Mar 13, 2025 1:41 PM UTC
Is it required for the variables to be defined in the same file where the component is? Or is it fine if I have the variables in the “Style Guide” file and the components in the “Component Library”? That’s really the only difference that I see that could prevent dev mode from changing the fonts. But again, the colors are also separated and they work just fine
Mar 14, 2025 5:39 AM UTC
Hi ​@Bruno31
Thanks for providing the details! I followed your steps and tested using a variable from the library file, and everything worked fine on my end. Could you please reach out to our support team by submitting a case? You can do so by following the instructions here: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report?
I hope our support team finds the solution for you.
Thanks for your patience!
Toku
Bruno31
Bruno31Author
Mar 14, 2025 11:53 AM UTC
Will submit it, thank you!
