Himangshu Biswas
Jun 1, 2026 10:40 AM UTC
changes appearing on the code but not in the design
After running the prompt, I can not see the changes in the design. When checked in the code, I found that the change is reflecting in the code but not reflecting on the design.
    Gayani_S
    Jun 1, 2026 12:04 PM UTC
    Hey ​@Himangshu Biswas, thanks for reaching out!
    Before I dig into this with you, I want to make sure I fully understand what you're seeing. The behaviour you're describing could have a few different causes, so I'd love to narrow it down first.
    1. Is this happening when you change a specific component property (like switching a variant or toggling a boolean), or does the mismatch appear in other situations too?
    2. When you say changes appear in the code but not the design — is the canvas staying visually stuck, or is it updating but the code panel showing something different?
    3. Does this happen on a specific file, or across multiple files?
    These are good first steps that can sometimes clear things up on their own:
    1. Hard refresh the file - Cmd + Shift + R (Mac) or Ctrl + Shift + R (Windows). This forces a full reload and can resolve temporary sync issues.
    2. Try in the browser - if you're on the desktop app, open the same file in Chrome or Firefox and see if the behaviour is the same. This helps us rule out a local app issue.
    3. Check for pending library updates - if the file uses a shared library, there may be an update waiting. Go to the main menu → Libraries and accept any pending changes.
    If none of those help, I can get you connected with our support team to dig deeper. To do that, please share your impacted file with support-share@figma.com and grant "Can view" access. This lets us reproduce the issue and investigate with Engineering if needed.
    Let me know how it goes!
    Himangshu Biswas
    Jun 2, 2026 6:54 AM UTC
    Hi,
    Please check version 338, 339, 341(all are same change).
    After reschedule details, added rebate details section. In the code I can sees a rebate section added but in the design it’s not reflecting.
    Link: [file link redacted by forum moderator to remove PII]
    Regards,
    Himangshu
    Gayani_S
    Jun 5, 2026 1:20 PM UTC
    Hey @Himangshu Biswas, thanks for sharing those details and your file link!
    We're connecting you with our support team to investigate this further. We've shared your file with them so they already have the context they need to dig in.
    Your ticket number is #1946022,  you can use this to track progress. Someone will be in touch with you soon, and we appreciate your patience in the meantime!
