RJO
Sep 17, 2025 3:04 PM UTC
Can't see distances between elements, even in Design mode and after trying everything
Problem description:
Hi Figma team,
Since the last update, I can no longer see the distance between elements when I select one and hold down the Option key (on Mac) while hovering over another. I’ve tried everything suggested:
  • Using Option or Alt + hover over another element.
  • Switching from Draw to Design mode in the bottom right of the interface.
  • Restarting Figma, opening new files, updating the app, clearing the cache, trying the web version, and even disabling plugins.
Nothing has worked and the problem persists, even though I used to see the measurements with no problem before.
I would really appreciate some help, since this tool is essential in my workflow and it’s causing me a lot of issues.
Thank you!
Junko3Solution
Oct 2, 2025 2:04 AM UTC
Hi there,
As some of you may have already noticed, our engineering team has released a fix for the recent issue.
If you’ve run into this problem recently, please refresh your tab and try using the shortcut again to confirm if it’s now working.
Thanks again for flagging this and for your patience while we worked on the fix!
4mation
Oct 2, 2025 12:53 AM UTC
I don’t know how...but this function seems to suddenly work now
S4Dnet
Oct 2, 2025 12:55 AM UTC
ITS BACK HOLY S##T ! GOD SAVE THE DEVS(or the dev) WHO FIXED IT
Raphael_Tsang
Oct 2, 2025 12:56 AM UTC
asdji1lk-02
Oct 2, 2025 12:57 AM UTC
I had a same issue
try
Check For Updates… > Reload All Tabs
maybe it will work!
Pokopower
Oct 2, 2025 12:58 AM UTC
Finally! I can measure distance again! I am invincible!!!!
casperskiyi
Oct 2, 2025 1:00 AM UTC
niiiiiice its fixed, restart your figma app
Junko3Solution
Hi there,
Stephen Kung
Oct 2, 2025 6:16 AM UTC
I don't have it either :((((
leti
Oct 2, 2025 6:17 AM UTC
Same issue. Tried on 3 accounts, 2 machines. I’ve tried freaking everything and I need to design my wedding dinner menu tonight.
​@fam hoped you see the update & did the dinner menu went well? 🤣🤣
borim.kim
Oct 2, 2025 1:08 PM UTC
​@djv
Mine was just solved after updating MacOS. Below is what I have now after the issue was solved.
I’ll add comments if it happens on my other Mac with the same setting.
- Latest Figma Desktop App version
- macOS Tahoe 26.0.1
- All types & all files
