RJO
Sep 17, 2025 3:04 PM UTC
Can't see distances between elements, even in Design mode and after trying everything
Problem description:
Hi Figma team,
Since the last update, I can no longer see the distance between elements when I select one and hold down the Option key (on Mac) while hovering over another. I’ve tried everything suggested:
  • Using Option or Alt + hover over another element.
  • Switching from Draw to Design mode in the bottom right of the interface.
  • Restarting Figma, opening new files, updating the app, clearing the cache, trying the web version, and even disabling plugins.
Nothing has worked and the problem persists, even though I used to see the measurements with no problem before.
I would really appreciate some help, since this tool is essential in my workflow and it’s causing me a lot of issues.
Thank you!
Junko3Solution
Oct 2, 2025 2:04 AM UTC
Hi there,
As some of you may have already noticed, our engineering team has released a fix for the recent issue.
If you’ve run into this problem recently, please refresh your tab and try using the shortcut again to confirm if it’s now working.
Thanks again for flagging this and for your patience while we worked on the fix!
Yahor
Oct 1, 2025 11:22 PM UTC
Same thing. Really annoying
Daniel Russell
Oct 1, 2025 11:30 PM UTC
seems the code is changing or conflicting when do some updates, let developer fix things up 😆
For a company this big, why are they not doing proper QA before releasing to prod?
Beech Agency
Same issue as well! Hope this gets fixed soon
Wahaj Moiz
Oct 1, 2025 11:32 PM UTC
Happened to me too..
S4Dnet
Oct 1, 2025 11:33 PM UTC
Hey, same problem here. Already re-installed the app, used the reset and restart but it just won’t work. The browser version is with the same problem tho. Might be a bug because it was working flawlessly about 2 hours ago.
Raissaelr
Oct 1, 2025 11:36 PM UTC
The same thing is happening to me too, and it just started a little while ago.
bizonio1989
Oct 1, 2025 11:40 PM UTC
+1 The same thing
I have already performed the following troubleshooting steps without success:
  • Restarted my computer.
  • Reinstalled the Figma desktop app.
  • Tested this in both existing and brand new files (the issue occurs everywhere).
  • Tested in the browser version of Figma, and the issue persists there as well.
None of these steps have resolved the problem.
amrgamal30
same issue here, this is very very frustrating and unacceptable
amrgamal30
Oct 1, 2025 11:42 PM UTC
​@djv please find a solution ASAP
Steven M
Oct 1, 2025 11:55 PM UTC
Workaround:
  • Set your zoom to 390%
  • Use calipers
