Carolina Cubillo
Jan 28, 2026 9:17 PM UTC
Can´t log in with my education email adress
I want to change my current gmail to my education email adress so that I can reverify as an Educator for my university. But, when I tried changing it, after I got the confirmation email and clicked the confirmation button, the following message appeared:
The email address cannot be updated: "..." is already in use
I don´t know what it means, since there’s no account linked to that email.
After that, I tried creating a new account with my education email, to try and solve the problem. But this other message appeared:
“That email and password combination is incorrect”
I dont know what else to do and I don’t understand what’s the problem with my education email. Ideally, i would prefer the first option (updating the email), so that I don’t loose all my files.
    Jan 29, 2026 2:14 AM UTC
    Hi ​@Carolina Cubillo,
    I understand that you’re trying to update your account email address to your university email so you can reverify as an Educator, but you’re running into issues when attempting to do so.
    I checked on our end and can see that your account has already been verified through SheerID.
    If you’d like to change the email address associated with a verified Education account, these requests are handled by our Education team.
    You can submit a request by completing the following form: Request to Move Figma EDU Status
    Requests are reviewed in the order they’re received, and the typical response time is up to 5 business days.
    Please note that your Education status is tied to the email address you originally verified with. If you update the email address on your Figma account on your own after verification, your Education status will be revoked.
    You can find more details about this in the guide: Figma for Education
    Based on the behavior you described, it also sounds like you may be using Google SSO to log in. If your account is managed through Google SSO, you won’t be able to change the email address directly within Figma.
    If you’d like to switch from Google SSO to an email-and-password login, you’ll need to remove Google SSO by setting a new account password. This will allow you to log in with an email and password and then update the email address on the account.
    Please be aware that following the steps below will revoke your verified Education status.
    You can find detailed instructions here: Switch from Google SSO to email and password
    Please try the option that best fits your situation based on the information above.
    Carolina Cubillo
    Jan 29, 2026 2:28 AM UTC
    Thanks a lot!! I will fill the form.
    But, what happens if my educational email isn't attached to an account yet? Can I still put it in the "Email  on account where Figma status is needed" field?
    And, can I still use that form if I'm changing from Gmail to an outlook email? (Just to be sure I understood!)
    Feb 9, 2026 2:36 AM UTC
    Thanks so much for following up! I may have misunderstood your situation earlier, but I now understand that you don’t yet have a Figma account associated with your school-issued email address.
    I’ll check with our team internally and get back to you once I have more information.
    Feb 10, 2026 12:30 AM UTC
    I’ve confirmed with our Education team that you can use that form for your case. We process these requests on a weekly basis and will let you know once the change has been made.
