Lu6
Apr 17, 2026 6:41 AM UTC
Can't find my Make Kit in Make
I recently created and published and design system Kit so that everybody in my organization can use it on Figma Make. But this kit does not appear on already existing Make files. It’s appearing though when I start new Make file. I also tried to duplicate my existing file but the kit doesn’t show up neither.
Apr 20, 2026 12:44 PM UTC
Hey ​@Lu6 , Celine from Figma here, thanks for sharing this!
This isn’t expected behavior. As a first step, could you confirm if both your existing Make files are in the same plan?
In the meantime, could you also try:
  • Refreshing the file
  • Reopening Figma (or using another browser)
If the issue still persists after that, the best next step is to submit a bug report so the team can investigate your specific setup: Go to the Support Hub Type “Report a bug” > Click Start a chat  and select Enter >
Please include in the form, the affected file(s) and your design system kit, and share Can View access with support-share@figma.com so the team can review directly. Feel free to let me know when you have filled out the form, I can escalate it internally. Thanks!
Jason Lockwood
Apr 23, 2026 1:35 PM UTC
​@Lu6 I’m also facing this issue.
I’ve refreshed my tabs, closed & restarted Figma, moved location of the Make file to team project space. However, I am uanable to apply this Make Kit to all projects. It’s as if it doesn’t exist in selective Make files.
Apr 23, 2026 3:25 PM UTC
Hey ​@Jason Lockwood , since you’re seeing the same issue and have already tried the steps above, could you reach out to the support team so they can investigate further? We haven’t got an update from Lu6 yet. Our support team will be able to take a closer look at what’s going on. To do that:  Go to the Support Hub Type “Report a bug” > Click Start a chat  and select Enter >
When you submit the request, please include links to the affected file(s) and your design system kit and share Can View access with support-share@figma.com so the team can review directly.  Thanks!
