Vito Amel
Feb 3, 2025 8:39 PM UTC
Can't change underline color via "Selection Colors"
I can’t change the underline color from Selection Colors. Changing the color there doesn’t trigger any changes
[redacted the file URL]
ksn
Feb 3, 2025 10:11 PM UTC
Hey ​@Vito Amel - first, wanted to let you know I removed the file link from your post (just in case you had sensitive info there you didn’t want made openly public).
Edit: I took a look at the original file you posted, and I don’t think I’m getting the full understanding of your issue. However, I don’t have full access to the demo file as it is, so I may not have all the right context.
Can you post a screen recording of what you’re describing instead? That would be very helpful.
Vito Amel
Vito AmelAuthor
Feb 4, 2025 11:59 AM UTC
Hello ​@ksn !
I recorded a video demonstrating a bug with changing the underline color via the “Selection Colors” panel.
https://www.loom.com/share/93890f877e304d06a034999586693d95?sid=3a8640cb-c446-47e2-98c6-f1aa1b294e6e
Feb 13, 2025 2:05 AM UTC
Hi ​@Vito Amel ,
I’m Toku from the same team as ​@ksn ! Thanks again for flagging. I was able to replicate the issue on my end, so I have filed a bug report internally. I can't provide an exact timeframe for a resolution, but I will keep you informed of any updates that I can share with you!
Thanks for your patience.
Toku
DGC
Mar 9, 2025 11:00 PM UTC
Similar but different to your ​@Vito Amel !
When creating a Type style for a link I noticed this bug that stops you seeing your local color styles.
Screenshots attached,
1/ CUSTOM TAB: “Created in this file” You can see the Local swatches
2/ LIBRARIES TAB: “Created in this file” is empty 🤔
