Can not get color of gradient linear by plugin api
  • April 26, 2024
  • 6 replies
  • 369 views
shun1
The gradientStops is empty array
  • April 26, 2024
Having the same issue,
based on your latest release note:
" Paint.ColorStop now has a new field boundVariables that contains a color field and denotes whether a variable is bound to a gradient color stop."
as I understand, the new field should be a new property in ColorStop.
but it’s just returning an empty array.
piusyikyu
  • April 26, 2024
Same issue here, I think it is their data model not being correctly migrated for already existing gradient objects.
If you edit the colour stops, the plugin api will send the data through again.
  • April 26, 2024
same problem
shun1
  • April 29, 2024
Is there no official response to this bug?
shun1
  • April 30, 2024
This bug was fixed!
James_Yang
  • Figmate
  • April 30, 2024
That’s correct. Thank you all for your patience. We rolled out a bug fix for this yesterday.
