Nabil_Eisa
Aug 29, 2025 8:25 PM UTC
bugs related to patterns
Hi ,
Here are couple bugs I encountered that are related to pattern fills
  • If a frame already have a pattern fill, you cannot add another pattern ,even if the current is hidden, the button just does not respond But you can copy a pattern and paste it to the frame just fine .
  • When using any stock image plugin like Unsplash or Pexels to add a background image fill to a frame , if the frame already had a pattern fill: nothing happens and the image does not get added, you can add it to other frames though , and again , you can copy the image fill from the other  frame to the frame with pattern fill  and it works just fine.
  • when you change the pattern source, all frames using it will update just fine in the editor , However not in present mode, in order for it to update in present mode you have to go the frame using the pattern and manually hide then show the pattern.
Hope these get fixed soon as they are pretty annoying.
And for reference all these bugs were encountered while using the desktop app with latest version.
Thanks
