Cristian_Banu
Jun 12, 2026 2:50 AM UTC
BUG: Stuff changes without me changing it
Hi,
Things change in the design, without me touching a thing. For example typography styles turn into Inter for no reason, or elements change their position, or their constraints, and this started happening ever since I staretd using the AI agent. They are not designs made by the agent though, so it’s not realted to the agent doing anything.
adamsmasher
Jun 12, 2026 10:39 PM UTC
Hi, ​@Cristian_Banu. That sounds like a confusing experience for you - thank you for posting about it.
The agent can edit anything in your design file. Given the nature of generative AI, it can sometimes produce imperfect results that may be inaccurate, incomplete, or not function as you may desire, and outputs will vary depending on the prompt, file context, and model used. Have you read our article on working with the Figma Agent? It gives guidance on how to best use the agent and get the results you want, including a best practices section.
Having said that, if you run into a situation where you do not think any work was performed or output was generated, let me know and I’ll help get you in touch with our support team.
