xMOx
May 9, 2026 8:15 PM UTC
Bug - Slot issue always breaking on me and change when I move or update component
Hi Figma, I’ve been facing issues with the new Slot feature
I have created a Row Component for my table, inside the Row Component I have a Slot that has 5 Cell Components in it. When I use my Row Component and adjust the Cells inside the Slot and then I Duplicate this entire mockup my table that has the Rows Component gets messed up and my Cells sizes shift/change.
Also sometime this issue happens after a library update, library doesn’t need to be updating the Row Component its just any update could also trigger it.
Can you please fix this issue as its causing me to need to clean up the design every time this happens to me.
Thanks
adamsmasher
May 10, 2026 9:06 PM UTC
Hey ​@xMOx!
Thanks for your post and thanks for the feedback - I imagine that’s pretty frustrating needing to fix this every time the component is updated. Our team is working to improve the slots experience while it's still in open beta, and the team is aware of this issue and is working on a fix.
In the meantime, have you tried regenerating instances? That can sometimes help. I wasn’t sure if you were doing that already or doing it by hand.
xMOx
xMOxAuthor
May 11, 2026 1:25 PM UTC
Hey ​@xMOx!
Thx Adam but I’m not sure what “regenerating instances” is. As of now I know, it sometimes fixes itself when I send an update or when I double click on the component and it re-adjust’s itself to its original set up that I had it before. But on other times it doesn’t work
