Javad_Saberi
Oct 15, 2025 7:34 AM UTC
Bug Report: Detach instance
Hello lovely Figma team,
Recently I’ve noticed that my icon components are getting messed up, and they only display correctly when I detach them. In the video below, you can see that the design system is implemented properly, so this issue seems to be a bug.
Oct 17, 2025 8:06 AM UTC
Thank you so much for your help!!
Javad_Saberi
Oct 20, 2025 8:19 AM UTC
​@Junko3
Hello, have the colleagues reached a conclusion?
Oct 22, 2025 7:29 AM UTC
Hi, I checked your support ticket (#1552209) and saw that our support specialist Nancy sent a possible solution to your ticket email a few days ago.
Could you please check your inbox, try the suggested steps, and then reply to that email rather than updating this forum post?
This will allow our specialist to continue investigating the issue with you.
Oct 24, 2025 2:10 AM UTC
​@Javad_Saberi
Thanks for confirming that you’ve reviewed the solutions sent to you via the ticket email.
I’ll make sure your comment is shared with the specialist handling your ticket. If anything else comes up regarding this issue, please continue the conversation by replying directly to the email thread with our specialist. I’ll go ahead and close this topic for now.
Thank you for your understanding!
Just in case, I’ve included an excerpt from your ticket (#1552209) below. Our team is waiting on your reply—please respond to the ticket email with an update on how things are going.
I noticed that there are three "invalid assets" in your Design System file currently. Can you please check the publishing modal and resolve any invalid assets (image below), as these will prevent a successful library publish?
Click on each to be directed to the component in your file where you'll see an error in the right-hand panel with more information.
Once you've resolved each, please try publishing your library once more to see if this fixes the problem.
