Trung Kien
Sep 7, 2026 9:12 AM UTC
Bug report: Copied designs lose layout and structure after some time
Subject: Bug report: Copied designs lose layout and structure after some time
Hi Figma Support team,
I'd like to report a recurring rendering bug that has been seriously affecting my daily work.
**Summary**
When I copy a design from one file and paste it into another file, the pasted design looks correct at first. After some time, however, it breaks: the layout shifts, elements are resized or repositioned, and the information structure (frames, auto layout, nesting, hierarchy) is corrupted. The copy no longer matches the original design.
**Steps to reproduce**
1. Open File A, which contains a finished design (frames with auto layout, components, text and color styles).
2. Select the design and copy it (Cmd/Ctrl + C).
3. Open File B and paste it (Cmd/Ctrl + V).
4. Verify that the pasted design renders correctly — at this point it does.
5. Close File B, then reopen it later (or return to it after some time).
6. The pasted design now renders with a broken layout and a corrupted structure.
**Expected behavior**
The pasted design should remain visually and structurally identical to the source: same layout, spacing, sizing, auto layout settings, and layer hierarchy.
**Actual behavior**
- Layout shifts; spacing and alignment no longer match the original.
- Elements are resized or moved out of position.
- Auto layout settings and layer hierarchy are corrupted.
- The overall information structure of the screen is broken and has to be rebuilt manually.
**Frequency**
[e.g. Happens almost every time I copy a design across files — at least X times in the past month.]
**Environment**
- Figma: [Desktop app / Browser], version [.....]
- OS: [e.g. macOS 14.5 / Windows 11]
- Browser (if applicable): [.....]
- Source file: [link to File A]
- Affected file: [link to File B]
- Approximate time the issue appeared: [.....]
**Impact**
I work on complex, data-heavy enterprise products, so a single screen contains a lot of nested structure. When a copied design breaks, I have to rebuild it from scratch, which costs hours of work, blocks developer handoff, and makes it risky to reuse designs across files at all.
**Attachments**
- Screenshot 1: the design in the source file (correct).
- Screenshot 2: the same design in the destination file right after pasting (correct).
- Screenshot 3: the same design after reopening the file (broken).
Please let me know if you need a duplicate of the affected file, a console log, or any other information to investigate. I'm happy to provide whatever helps.
Thank you,
[Your name]
[Role — Company]
[Figma account email]
