Prateek Tiwari
Jul 14, 2025 10:08 AM UTC
Bug: Figma Make shows "Try again with fewer inputs" even for short prompts after a few successful ones
I've been experimenting with the new Figma Make feature and noticed a recurring issue that's affecting usability:
  • After about 8–10 successful prompts (each 1–2 lines long), Figma Make starts rejecting any further prompt with the message:
    "Try again, with fewer inputs."
  • This happens even when the prompts are extremely short, e.g., "Create a dark-themed button component" or "Add a CTA section with three buttons."
  • I’ve tested this across multiple projects and browsers. The issue persists consistently, and the only workaround seems to be refreshing the tab, which sometimes helps temporarily — but not always.
Additional Context:
  • Even though Figma Make is currently laggy while generating prototypes (which I can overlook), this input rejection bug makes it difficult to iterate quickly or finish design ideas.
  • It feels like a silent rate-limit or session exhaustion issue that’s not clearly communicated to the user.
Thierry_Lemaitre
Jul 23, 2025 6:06 PM UTC
​@Tom Reem Hello figmate!
I didn’t use figma make before and this is the first time using it. I copy paste a frame from my design with a prompy, but I’m getting the error “Try again, with fewer inputs”. Is it the same problem or it’s from something else?
Thank you!
Andy33
Jul 25, 2025 11:29 AM UTC
Same issue, whatever i do.
Shid
Aug 2, 2025 12:55 AM UTC
Will Figma solve this problem, or at least provide a more meaningful error message ?
Laura_Linares
Aug 2, 2025 1:28 AM UTC
Hi there! I got a similar response in Design when trying to send a frame to Make, after clicking the option ‘Send to Figma Make’ — just right-click on any design frame, and you’ll find the option at the top.
After reducing the number of layers, detaching components, and cleaning the file a lot (I only kept a sidebar and a couple of analytics components), the system kept prompting the same error. I even tried sending just one component, and it still didn’t work.
Hope this helps, and that someone at Figma sees this.
Thanks!!
