Charan-CareSmartz360
Feb 27, 2026 3:10 PM UTC
BUG: Figma Make completely ignores attached Library & Guidelines (Drained 250+ credits)
Hi Figma Team,
I am reporting a severe bug with Figma Make that resulted in a completely hallucinated design and the unfair loss of ~250 AI credits on my Professional plan.
I attempted to generate a specific dashboard ("v3 / dashboard") using my "Caregiver Web Portal" design system. Despite attaching my local library and providing explicit rules in Guidelines.md, the AI failed completely.
The Issues:
  • Ignored Libraries & Guidelines: The tool completely ignored my attached components and explicit styling rules, hallucinating an entirely different and unusable UI.
  • Server Crashes: I hit multiple "Model is overloaded" errors and endless Vite preview engine spinners.
  • Massive Credit Drain: One single incorrect generation cost me 172 credits. In total, I have lost nearly 250 credits to these bugs and server failures.
My Ask: Please investigate why Figma Make is ignoring attached libraries, and I am formally requesting a refund of the ~250 credits wasted by these system failures.
Evidence Attached:
  1. Screenshot 1: The red "Model is overloaded" server error.
  2. Screenshot 2: The final hallucinated output (costing 172 credits) that looks nothing like the attached library or prompt instructions.
  3. Screenshot 3: This is what I wanted
Celyn_L
Mar 2, 2026 8:40 AM UTC
Hi ​@Charan-CareSmartz360 — Celyn from Figma Community Support here.
Thank you for taking the time to document everything so thoroughly and include screenshots — that context is incredibly helpful for our review.
I’m sorry to hear that while trying to generate a dashboard using your attached design system, you encountered repeated “Model is overloaded” errors and received an output that didn’t reflect your provided library and guidelines.
I understand how frustrating it must be to have credits consumed on a generation that didn’t produce the intended result.
To make sure this is properly reviewed, I’ve created a support ticket (#1770959) on your behalf so our Technical Quality team can investigate what happened and follow up with you directly.
As next steps, please check the inbox associated with your Figma account and reply directly to that email with:
  • A screen recording showing the behavior end-to-end, with the full Figma window visible
  • Please also share your impacted file with support-share@figma.com and grant “Can View” access — this will not impact your billing and will allow us to reproduce the issue and investigate further with Engineering.
Thanks again for flagging this, someone from our team will be in touch with you shortly.
Mar 2, 2026 9:48 AM UTC
Hi Celyn,
Thank you for the update and for setting up the ticket.
Regarding the request for a screen recording, I am unable to replicate the process again as it consumes a significant amount of credits, which I have already lost without result. Furthermore, I do not recall the exact sequence of steps taken during the failed generation, and I have already shared all the details, screenshots, and context I have available in my previous reports.
I have shared the impacted file with support-share@figma.com with “Can View” access as requested. Since the "Model is overloaded" errors and the failure to recognize the library are logged within your platform’s backend, I hope the Technical Quality team can use the existing data and the file access to investigate further.
As each credit is very important to us, I look forward to your team’s review and a resolution regarding the refund for the failed sessions.
Mar 11, 2026 1:20 PM UTC
Still waiting for reply.
Celyn_L
Mar 13, 2026 10:06 AM UTC
Hi ​@Charan-CareSmartz360, thanks again for sharing the impacted file with support-share@figma.com, and no worries at all about not being able to send a screen recording — we completely understand.
I’m sorry to hear that you haven’t heard back from the team yet. I’ve gone ahead and escalated this internally for you, and they should follow up as soon as possible.
We really appreciate your patience while we work through this 🙏
Dapas Media
Apr 7, 2026 6:42 AM UTC
I have lost nearly 500 AI credits, but the design was not updated at all—everything remains the same. I would like to request a refund of my AI credits.
Dapas Media
Apr 7, 2026 6:43 AM UTC
https://www.figma.com/make/wYBJYQlmektmdQCPnC80EY/CRM-for-Clinic-Management?t=x1PkwykZSn9w1lpj-1
Celyn_L
Apr 7, 2026 8:12 AM UTC
Hi ​@Dapas Media — thanks for flagging this and also for sharing the screenshots and the file link, that context is really helpful.
I’ve located your support ticket (#1833791) and have escalated it internally to increase visibility with the team. They’ll take a closer look at what may have caused the credits to be consumed without any changes reflected in your design.
In the meantime, please also share your impacted file with support-share@figma.com and grant “Can View” access. This won’t affect your billing, and it helps us reproduce the issue and investigate further with Engineering.
Please keep an eye on your inbox, the team will follow up with next steps as soon as possible.
Thanks for your patience while we look into this 🙏
