Tabish Rafiq
Jul 8, 2026 8:17 PM UTC
[Bug] Auto-keyframe doesn't trigger for position/rotation changes via Plugin API (Motion Beta)
When auto-keyframe mode is enabled in Figma Motion, property changes made through the Plugin API behave inconsistently:
  • Stroke width (strokeWeight) — changing this via plugin correctly adds a keyframe at the current playhead position
  • Position (x, y) and Rotation (rotation) — changing these via plugin does NOT add a keyframe, even with auto-keyframe toggled on
Steps to reproduce:
  1. Enable Motion mode and turn on the auto-keyframe toggle
  2. Select a node
  3. From a plugin, set node.strokeWeight = someValue → keyframe is added automatically
    From the same plugin, set node.x = someValue or node.rotation = someValue → no keyframe added
Expected behavior: All property changes made via the Plugin API should respect the auto-keyframe toggle, just like changes made through the UI do.
Workaround: Manually call applyManualKeyframeTrack for TRANSLATION_X, TRANSLATION_Y, and ROTATION at the desired time — but this requires knowing the current playhead position, which is also not exposed in the Plugin API (a separate gap worth addressing).
Jaycee Lewis
Jaycee LewisSolution
Jul 29, 2026 10:35 PM UTC
Hey hey ​@Tabish Rafiq 🤩 Guess what? Playhead position is available in the Plugin API! Please try it out and let me know what you think. Have fun testing! — Jaycee
Jaycee Lewis
Jul 8, 2026 10:14 PM UTC
Hey ​@Tabish Rafiq 👋 Thank you so much for the thoughtful and complete example. I took your main feedback and your comments about the workaround to the team that owns these features. I’ll follow up here if I get us any additional guidance. Talk soon! – Jaycee
Tabish Rafiq
Jul 9, 2026 9:08 AM UTC
​@Jaycee Lewis Thank you! Looking forward.
Jaycee Lewis
