Frank Vo
Apr 8, 2026 4:34 AM UTC
BUG: Assets Floating Panel and Prototype bugs
Assets floating panel bug. The panel is cut off, and some items are out of view.
Another bug. When renaming a prototype, I can no longer use the left/right arrow keys to move between characters. Instead, they select all of the text.
    javaria.c
    Apr 9, 2026 1:31 PM UTC
    I am experiencing the same problem with the assets panel.
    sarah.klos
    Apr 9, 2026 4:26 PM UTC
    I am also experiencing this problem!
    Apr 10, 2026 7:44 AM UTC
    Hey everyone, thank you for flagging this! About the Assets Floating Panel bug, our team is aware of this issue and is proactively trying to fix. We’ll share an update as soon as we have one. Thanks for your patience in the meantime!
    ​@Frank Vo , regarding the other issue you mentioned:
    I wasn’t able to reproduce this on my end. Please try to force-quit Figma and restart to see if that helps. If you’re still seeing it, could you please submit a bug report so the team can take a closer look?
    To do so: Go to the Support Hub / Type “Report a bug” / Click Start a chat and select Enter.
    If possible, please also share the URL of the file, and grant "Can View" access with support-share@figma.com. This will help the team reproduce and investigate the issue, thank you!
    Apr 13, 2026 10:47 AM UTC
    Hey everyone! Regarding the assets floating panel bug, our engineering team has released a fix! Please refresh you browser and/or desktop app tabs, thank you!
