Mohan kumar
Sep 13, 2026 3:54 AM UTC
Badge Name Clarification
Hi Team,
I just wanted to confirm how the name will appear on the Config India 2026 badge. I noticed that I’m unable to change my last name in the registration details, so I wanted to check whether the badge will display only my first name or my full name.
I’m asking just to make sure my name doesn’t appear incorrectly or in an unusual format on the badge.
Thank you!
Mohan kumar
Mohan kumarSolution
Oct 7, 2026 7:50 PM UTC
@adamsmasher Thank you so much for bearing with me! Really appreciate your help. 🙌
adamsmasher
Sep 13, 2026 3:18 PM UTC
Hi, ​@Mohan kumar! Thanks for your post and glad to hear that you’ll be attending Config India this year!
Is there a typo or misspelling of your last name with your registration? I’m going to check with the team regarding your question, but I’ll also find out if it’s possible to update it if there’s an issue.
Mohan kumar
Sep 13, 2026 4:51 PM UTC
Hi Adam, thanks for checking! There isn't a typo in my registered name.[Redacted by moderator - 2026/09/13] is my surname/last name, and Mohan Kumar is my first name.
The issue is specifically with the badge information. It currently shows “Mohan kumar” for both the preferred first name and last name, while the last name field is locked and I can't edit it to “[Redacted by moderator - 2026/09/13].”
So I just want to make sure my badge is correctly printed as Mohan Kumar [Redacted by moderator - 2026/09/13] or Mohan Kumar and I updated my first name as [Redacted by moderator - 2026/09/13] it is good if my full name was printed like [Redacted by moderator - 2026/09/13] mohan Kumar but issue is  only if the first name was printed as "[Redacted by moderator - 2026/09/13]" Thanks so much for checking with the team!
adamsmasher
Sep 13, 2026 7:39 PM UTC
Ok, thank you for clarifying! While I did redact your last name in your reply for privacy reasons, I did share it and the proper formatting of your name with the team. They said they would update the badge for you. 😊
