Brett Dorrans
Aug 10, 2026 9:37 AM UTC
API auth bug: files/:file_key/styles returns 400 "Missing valid token credentials" for a PAT that succeeds on /components and /component_sets
GET /v1/files/:file_key/styles rejects a valid/correctly scoped PAT while the two sibling endpoints - GET /v1/files/:file_key/components andGET /v1/files/:file_key/component_sets - accept the exact same token against the exact same file. This appears to be a regression introduced between 2026-08-07T15:58:51Z and 2026-08-08T07:37:18Z.
The response is:
HTTP/2 400
{"error":true,"status":400,"message":"Missing valid token credentials","i18n":null}
Endpoint Time (UTC) Result Request ID
2026-08-10T09:11:58Z
400
b7838db7-0de6-4fae-958b-4bd89457e19c
2026-08-10T09:11:59Z
200
f2e913d8-63be-4b3d-9926-d515f10b86ed
2026-08-10T09:12:00Z
200
70742e97-1695-4c2f-9237-ed155c896855
The token is valid and correctly scoped. Everything else we call succeeds:
- GET /v1/me → 200
- GET /v1/files/:key?depth=1 → 200
- GET /v1/files/:key (full) → 200
- GET /v1/files/:key/nodes?ids=… → 200
- GET /v1/files/:key/meta → 200, reports role: owner
- GET /v1/styles/:key → 200 for individual published styles in this same file
It used to work with this same token. Our committed baseline snapshot was generated from this endpoint on 2026-08-06 at 16:01 UTC+1 and captured 27 styles. The first failure we observed was 2026-08-08 at 07:37 UTC+1. Nothing changed on our side in between - no token rotation, no code change to the call. We found no entry in the REST API changelog for that window.
Reproduction Steps
This is 100% reproducible with the above information. Something has changed Figma side.
  1. Create a personal access token, ticking every scope offered in the UI.
  2. Run, substituting the token:
FILE=...
for ep in styles components component_sets; do
printf '%-16s ' "/$ep"
curl -s -o /dev/null -w 'HTTP %{http_code}\n' \
-H "X-Figma-Token: $FIGMA_TOKEN" \
"https://api.figma.com/v1/files/$FILE/$ep"
done
  1. Observe:
/styles          HTTP 400/components      HTTP 200/component_sets  HTTP 200
Expected: HTTP 200 from all three, per the identical security blocks in the OpenAPI spec.
Jaycee Lewis
Aug 10, 2026 8:54 PM UTC
Hey Brett! Thanks for your post and for including your details! It’s very helpful. I opened a support ticket for this. The ID is 2063872 and the ticket subject line is GET /v1/files/:file_key/styles returning 400 "Missing valid token credentials". Please keep an eye on your email inbox (and spam folder) for the ticket and for any replies from out technical quality team. Best! — Jaycee
