Cassidy
May 12, 2025 2:29 PM UTC
Annotations disappearing when I zoom in
Hi there! I’ve been loving the new annotations feature, but have been experiencing an issue with it over the past couple of days. When I’m looking through my designs and try to zoom in, all of the annotations disappear before I can get close enough to see what they’re attached to. Has anyone else experienced this?
Jaclyne_Ooi1
Jaclyne_Ooi1Solution
May 13, 2025 3:31 PM UTC
Just started running into this today with one particular annotation.
The bounds of my outermost frame were smaller than the content within it (This was on purpose to allow for scrolling in prototypes)
The element I was trying to annotate was outside of those bounds, but it was still visible since I didn’t have “clip to content” enabled on the frame.
I made the outer frame larger to fully contain all the content and that seemed to stop the annotation from disappearing on zoom.
Jaclyne_Ooi1
Cassidy
CassidyAuthor
May 13, 2025 7:08 PM UTC
​@Jaclyne_Ooi1 Thank you so much for your response! It seems like that’s the issue! Hopefully it’s something they fix in the future because we usually design with a smaller frame to allow for scrolling too.
Lasma
Jun 3, 2025 12:03 PM UTC
Hi. I have the same bug, they keep disappearing and appearing whenever they want, when I zoom in they are invisible and right after I make one it also disappears. Very cool feature but so far making me very frustrated.
Cassidy
CassidyAuthor
Jun 3, 2025 2:13 PM UTC
​@Lasma I found that the highlighted answer from ​@Jaclyne_Ooi1 gave me context as to why they’re disappearing. When I design, I have the frame at the height of whatever screen I’m designing for, so when there are annotations on content that technically goes off of the frame, those tend to disappear. Definitely an annoying bug, so hopefully they fix it soon!!
Cornelius_Kluge
Oct 2, 2025 6:42 AM UTC
Had the same issues. Also, resizing the uppermost frame did not fix the issue.
What helped me was removing the outermost frame (Ctrl/Cmd + Backspace). In my case, I first had a doubly-nested setup, so I could luckily just replace the outermost static frame with the underlying auto-layout frame. Hope that helps anyone still looking for a fix!
Amanda2
Mar 18, 2026 3:51 PM UTC
Just running into this today - ideally an annotation always shows, as I often have dev-ready frames set up for prototype purposes
Bartosz Skotzke
Apr 9, 2026 12:09 PM UTC
Cutting and re-pasting the frames into the section again helped solve this issue
