CharleneAtlas
Jun 12, 2026 9:16 PM UTC
AI Credits Used Up On Failed Attempts
Hi, I think I may have lost AI credits due to failed generations, and I’m also seeing conflicting UI messaging.
I initially entered prompts through the main AI prompt text input while on the Files page, but both attempts failed with “Something went wrong” errors (example ID: 55a3160f-8fcc-4aca-82ac-0ad25065a110). Nothing was ever successfully generated from those attempts.
After that, I backed out and tried again from a blank FigJam board instead (which I believe is the intended workflow for brainstorming/mind maps), but it then said I was out of AI credits and would not let me run the prompt — so I was unable to generate anything there either.
What’s confusing is that I’m seeing conflicting credit information:
  • A banner says: “Your Full seat is out of AI credits until they reset on Jun 12”
  • But the AI balance panel shows 316 credits remaining, with 0/150 daily credits left and a Jun 30 reset date.
It seems possible the failed requests still counted against my daily credits, or there may be a UI issue/conflicting state. I’ve attached screenshots for reference.
Would it be possible to review and restore any credits associated with the failed requests, or clarify what happened? At no point did an AI-generated output actually complete or appear. This was my first time trying Figma AI.
Thank you!
Jul 15, 2026 6:03 PM UTC
Hi ​@seclusio.ai, thanks for following up!
I’ve created ticket #2017262 on your behalf to connect you with our product support team. Someone will review your account and be in touch with you as soon as they’re available.
