TimurInSpark
Mar 11, 2026 9:48 AM UTC
After subtracting the shape, extra dots appear in pixel-free mode.
Problem
After subtracting pixel imperfect shape, extra dots (artefacts) appear on outside contour.
Extra dots after substraction non-pixel-perfect shape after stroke outline.
How to reproduce
With Snap to pixel grid disabled:
  1. Add a shape (circle)
  2. Add stroke to the shape
  3. Make Outline stroke
  4. Substract stroke from circle
  5. Flatten shape
The process of reproducing the error.
Importance
Due to this artifacts it is hard to use figma for illustration. In my workflow I need to repeat this steps several times on different shapes and this generates a lot of artefacts.
TimurInSpark
Mar 12, 2026 1:43 PM UTC
As an alternative to subtraction, I tried Split vector (in Figma Draw mode from context menu) and it works. No artefact dots. But this way generates a lot of other vectors (in case of complex form), that I should remove, so I hope that the error with substruct will be fixed.
The goal is to crop the shape along the contour by the same amount. Simple shapes can be simply resized, but in the case of complex ones, this does not work.
Should I register this original question as a bug somewhere?
TimurInSpark
Mar 14, 2026 12:39 PM UTC
The other way is to make a centered stroke with double the thickness.
