정재석
Jun 9, 2026 7:37 AM UTC
프로페셔널 Dev 시트를 먼저 유료 구매했는데 이용중에 실수로 풀 시트가 추가되어 2중 과금될것같습니다.
다음달 청구가 총 $40달러로 예상된다고 하는데 이중과금되는것같아서 $15 결제한 Dev 시트를 취소하고 풀 시트만을 이용하고 싶습니다.
과금 체계가 이해가 잘 안됩니다. 환불이나 변경이 가능한가요?
I initially purchased the Professional Dev Seat, but a Full Seat was accidentally added while I was using it, and it appears I will be double-charged.
I am told that the total bill for next month is expected to be $40. Since this seems like double billing, I would like to cancel the Dev Seat I paid $15 for and use only the Full Seat.
I do not quite understand the billing system. Is it possible to get a refund or make a change?
Celine_Solution
Jun 9, 2026 10:07 AM UTC
Hi ​@정재석 , Celine from the Community Support team at Figma here, happy to assist! I understand you'd like to cancel the Dev seat and keep only the Full seat, and you're wondering whether a refund is possible for the accidental charge.
To clarify how Figma's seat system works: a Full seat already includes everything a Dev seat covers, so you're right that having both would result in being billed for two seats unnecessarily.
Here's what you can do right away: from the file browser, click  Admin in the left sidebar > Select the  People tab > Click a person’s current seat from the Seat type column> In the popup modal, select and confirm the new seat typ.> From here, you can downgrade the Dev seat to a free View seat. This will make sure you're only billed for the Full seat going forward.
These articles may help:
As for the refund, our support team will be best placed to review your billing in detail and advise on what's possible (we're unable to handle billing requests directly from the Forum). I can see your existing support ticket (your case number is #1951170) and have added a follow-up note for you. Please keep an eye on your inbox for their response! Thanks for your patience 🙏
Update: Great news! Our support team has reviewed your upcoming invoice and confirmed that it has already been adjusted. The Dev seat that was added by mistake has been removed, so you won't be charged the original amount. 🎉
Please check your inbox for the full details, and feel free to continue the conversation via your support case if you have any further questions. I’ll go ahead and closed the thread here, thanks for your patience!
Celine_Solution
