Figma PDF exports were too big even with compression plugins, so I created my own solution.
  • March 20, 2026
  • 46 views
Hossaena
TL;DR: Figma’s PDF exports (even with paid plugins) gave me huge, laggy files, so I built my own tool that exports slides as compressed images, rebuilds the PDF with OCR, adds all links, and got a 48-slide deck from 177MB down to 11MB with smooth performance.
The title basically says it all...
I’ve been tryna properly export Figma presentation decks to PDFs for like 3 years now, and every option I tried just wasn't doing enough for me. I’m not even gonna get into Figma’s default pdf export, but even $20/month plugins like Compressed PDF and TinyImage Compressor still gave me pretty chunky PDFs (typically over 100mb for 30 to 50 slides).
And it wasn’t just the file size either. The PDFs would feel janky as hell when scrolling, stuff would flicker, the scrolling itself would lag A LOT, and sometimes the design itself would get messed up when the plugin tried to optimize vectors, glows or other weird effects. My decks usually have a lot going on too, like I abuse gradients, glows, vector shapes, blend modes, noise textures, high-res images, all that fun stuff. So it made the whole problem worse.
I looked this up a bunch over time and it seems like a lot of people run into the same issue with Figma PDFs (even this figma forum is filled with such posts). At some point I remember seeing someone suggest exporting frames as images, compressing those, and then combining them into a PDF. And honestly... that actually helped a lot. The file size got wayyyy better, and the flickering problem completely went away too.
But that too, ofc, wasn't without its tradeoffs... you lose searchable text, and all hyperlinks are gone too, because it’s just images. So my cursed workaround for a while was basically: export frames as images, compress them manually with ImageMagick cli, combine them into a PDF with PDF24, run OCR on it, then go into sejda.com and manually draw link rectangles over every link in the deck (and I typically have my agency website link in the footer of all the slides😭). And if I changed even one thing in the design, I’d have to go do that whole mess again. it was painful as hell, but I didn't have any other choices.
So I finally got tired of it and made my own local Figma plugin + localhost script setup that automates the whole thing I was doing manually. It exports the frames as images, compresses them, runs OCR, builds the PDF, and adds the links back in automatically.
For reference, I tested it on the same 48-slide pitch deck. Pretty effects-heavy deck too, lots of glows, gradients, images, vectors, blend modes, etc. Here’s what I got:
  1. Figma default export - `177 MB` 💀
  2. TinyImage Compressor - `153 MB` (using default Create PDF settings, and it was slow as hell too when exporting)
  3. Compressed PDF - `83 MB` (only for 40 slides because of the free limit, and this was on high quality, not the default very high quality)
  4. My new plugin - `11 MB` (on balanced mode, maintaining the same quality without any noticeable pixelation, it exported much faster, and the PDF scrolled normally with no flicker and lag)
Yeah ik this flattens everything, but there really is no better option at this point. It's crazy how there has been no real solution to this issue all these years.
But yea, I just finished the prototype and it’s been working very well for me locally. I'm definitely using this plugin for all my future projects. Anyways, I'm sharing this post to see if you guys would actually use this tool, if so, I can tidy it up more and publish the plugin.
