vulpes
Feb 22, 2025 9:54 AM UTC
Wireframe Kit from Community -> Can't publish library
I'm just working my way into Figma.
I downloaded a wireframing kit from the community and wanted to publish it as a shared library.
When I click on “Publish”, the Figma window dims briefly, then the wireframe file is visible again, but nothing has been published. I have no access to the components from another file (the library is not displayed for selection). Identical with another wireframing kit.
What could be the reason for this? If I create components myself and share them as a shared library, it works without any problems.
Thanks for your support!
y_tokuSolution
Feb 26, 2025 4:32 AM UTC
Hi ​@vulpes
Thanks for reaching out. Could you please double-check if the file has been moved to a team in your account? Files downloaded from the Community usually appear in your drafts at first, so you’ll need to move them to a project before publishing. If the file is already in a team, do you see any invalid assets or error messages when trying to publish? If the issue persists, could you share a screen recording?
Thanks!
Toku
y_tokuSolution
Hi ​@vulpes
Thanks!
Toku
vulpes
vulpesAuthor
Feb 26, 2025 6:18 AM UTC
Hi Toku,
the hint with the drafts solved the problem.
Thanks a lot!
