Tara
March 18, 2021
Why Can't I Publish Components to My Library?
  • March 18, 2021
  • 5 replies
  • 9774 views
I published a Design System library with all our color, layer and text styles. I then created a sandbox file to play around with component variants for the buttons since i’m a newbie. I copied the variants to my Design System file and it shows up in the components, however I’m unable to publish (it’s saying the file is published and up to date). Also to note it says “Enable libraries for all team files from your team settings”, not sure if that’s a reason for being unable to publish.
Thank you for your help in advance!
Latest update: I checked the ‘Design System’ team (houses all DS’s) and the library is enabled.
Screenshot below. Note the dot on the library (indicating changes to library file) yet it says published and up to date in the library publishing modal.
Power Member
March 19, 2021
First of all, publishing components is a premium feature so make sure your file is in the Professional, Education or Organization team. If it is, there is a possibility that the components were removed from publishing, you can add them to publishing by right clicking in the left Assets panel and selecting “Add to library”.
Ben_B
November 12, 2022
I was told that Figma is free. I’m learning Figma, but it seems to be a trap in the middle of learning. 😂 I can’t continue learning and finish the online course that I took. 🤣
I emailed the Figma support team, but I haven’t received any messages. 🥰
Power Member
November 12, 2022
If you are learning, you are eligible for an Education license. However you don’t need libraries in order to be good at design and Figma. They are an advanced concept for teams and huge projects. For learning it’s ok to keep everything in one file.
Ben_B
November 12, 2022
Thank you, I didn’t know that. I’m just following the Masterclass.
Mohsen_GMD
August 16, 2023
Another thing to mention, if you have duplicate property value in components or an unused property, Figma won’t publish the changes unless you make the components clean and standard.
