Surandip Nayak
Sep 2, 2025 3:20 AM UTC
Why am I unable to use the glass effect in Figma?
I'm having trouble using the glass effect in Figma and I'm not sure what I might be missing. Is there something I might be missing or any common issues to check?
I've been trying to apply a glass effect to my designs but it doesn't seem to be working as expected. I'm wondering if:
- There are specific requirements for using the glass effect
- It might be related to my subscription plan or account type
- There are certain conditions that need to be met for it to work properly
- It's a known issue that others have experienced
Any guidance or troubleshooting tips would be greatly appreciated!
Sep 2, 2025 5:43 AM UTC
Hi ​@Surandip Nayak ,
I understand you're having trouble using the glass effect in Figma.
To clarify, effects( including the glass effect ) are available on any plan, and anyone with can edit access to a file can apply and adjust them.
Just to better understand your situation, are you unable to apply the glass effect at all? Or are you able to apply it, but it's not producing the expected result?
Thanks!
Surandip Nayak
Sep 2, 2025 6:03 AM UTC
I am unable to apply the glass effect at all. The option is visible, but it is completely greyed out and not accessible.
Sep 3, 2025 6:28 AM UTC
Hey, which layers are you trying to apply the Glass effect to?
As mentioned above, the Glass effect can only be applied to frames. Also, please note that only one Glass effect can be applied per frame.
If your setup meets these conditions and you're still unable to apply the effect, could you please share a full Figma screen screenshot that includes both the left and right panels, with the layers panel expanded?
This will help us better understand what you're seeing and how we can assist you more effectively.
