lwilkins5000
Jul 7, 2026 7:51 PM UTC
When using “Present” mode the interactions aren’t displaying correctly
Similar issue: When using “Present” mode the interactions aren’t displaying correctly. A simple list of expanding/collapsing containers fails to open any of the containers except 1, despite tapping on other containers. This isn’t happening in Mirror or in “Preview” mode.
    Jaycee Lewis
    Jul 7, 2026 8:33 PM UTC
    Hi ​@lwilkins5000 I moved this to its own post so we can troubleshoot together.
    A couple things that’ll give us more info on what's happening:
    • Could you share a quick screen recording of Present mode where you tap through a few of the containers in sequence (including ones that don't open)? That'll show which taps are and aren't registering
    • Are all the containers separate instances of the same interactive component, or one instance duplicated. If so, are they sharing a single variable/state, or does each have its own?
    That should help with whether this is a Present-mode bug or something in how the containers are wired up.
    Thanks! — Jaycee
    lwilkins5000
    Jul 7, 2026 9:06 PM UTC
    Thanks! — Jaycee
    This was one component animating across variations.
    I was able to fix it by deleting all Flow Starting points in the file and re-adding them.
    I tried it again with a different proto (in the same file) that didn’t have a flow starting point assigned, and it also started behaving strangely, so I guess I’ll make sure every single sample has a flow starting point? This has only recently been an issue, I don’t normally use a separate starting point for the small tests that I run.
