Oct 9, 2023 4:59 PM UTC
When I click "continue" button on the "Open this link? popup", the popup does not close
Hello
“Open this link?” When I click “continue” button on the popup, the popup does not close.
I was aware of the email exposure warning, but it seems strange that it doesn’t work.
Because of this, I can’t do my existing work. Sorry, but please check quickly.
Dec 12, 2023 4:16 PM UTC
Hey All, sorry to hear you’re still running into this issue!
Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, so we can take a closer look into this issue.
MichelleW
Dec 29, 2023 6:47 PM UTC
I’m having the same issue also - I did recently change my email address but it never affected my access with this particular client before.
I’ve asked them to remove my access to the file and reinvite me. I will see if that helps.
But I’ve tried all that everyone has suggested here.
Has anyone got a response from Figma directly?
Jan 11, 2024 9:08 AM UTC
I think this issue occurs mainly when the type of account for the person sharing does not match the type of account of the viewer. As far as I understand, this is a front end bug/API connectivity bug that you can technically bypass if viewing in browsers by right clicking on the modal overlay div → Inspect → and then removing the modal div from the page.
Please note that this is simply a workaround and cannot guarantee results - use with caution. This is definitely a bug that Figma needs to fix. Additionally, you cannot use this workaround when using the desktop application.
Note to Figma team: If you cannot fix the issue, please still allow the workaround 😊
