Numa_Qureshi
May 24, 2022
Vertical and horizontal resizing reversed?
  • May 24, 2022
  • 14 replies
  • 2785 views
I don’t know what’s happened to my controls all of a sudden, but whenever I type a number into the width box in the right panel, the height of the frame changes, and vice versa. When I type a number into the vertical padding box, the horizontal padding of the frame changes and vice versa. It’s an issue both in the browser version and desktop app. I think I might have accidentally pressed some weird keyboard shortcut but I’m not sure and I don’t know how to fix it
ISIDORA_PAZ_CARRASCO_ZAPATA
July 11, 2022
have u fix it?
tank666
July 11, 2022
Make sure your object is not rotated or flipped.
Anna_Kuti-Krvavac
February 24, 2023
I have the same issue for 2 days now. Is there any fix for this?
@tank666 It’s definitely a bug, now it even places my components flipped when I drag them on a screen 😦
tank666
February 24, 2023
Check your main component. This “bug” only happens when something is rotated/flipped. Take a close look at the rotation values, object coordinates, and the transform CSS property in the Inspect panel.
You can also share a link to an example file here so anyone can help find the cause.
Anna_Kuti-Krvavac
February 24, 2023
Thanks for your answer!
I started to build another component, again, from a horizontal text layer. I add auto layout and it reverses horizontal and vertical values, but on the canvas it looks the same. In CSS it appears with transform -90, but only after adding auto layout. I made screenshots of the CSS before and after shift+A.
With the previous component this was the same issue, but I went along with it because I have a deadline and thought it’s just a temporary thing, closed Figma (desktop version), restarted the PC, nothing made it go away. As soon as I add an auto layout, this happens. I don’t know how to resolve this, can anybody help please?
Anna_Kuti-Krvavac
February 24, 2023
Power Member
February 24, 2023
This happens because the main frame where you are creating an auto layout object is rotated.
Anna_Kuti-Krvavac
February 24, 2023
@Gleb so first I didn’t understand this because I didn’t rotate anything. Then I realized that I resized a huge frame to fit all components on it. It is now landscape and was portrait before. Wow.
2 days headache for a bad move. Thank you Gleb!
Agni_Kaster
Kinda late to the conversation, but just wanted to follow up for anyone else also having the same issue and wants to avoid having it in the future.
There’s a setting under Figma/Settings/Flip Objects While Resizing
→ make sure this is unchecked
Note: you need to keep it checked while you are doing the fix described above, but after you are in a good spot, just turn the setting off.
August 28, 2024
Just checked - there is no ‘Flip Objects while Resizing’ in settings. what do I do now?
