Christian_Leon_Christensen
Apr 12, 2021 8:38 AM UTC
Variants in prototypes not sticking
The interactive variants are not displaying the overrides I set, when presenting
Component A has variant named hover.
The component contains dates, so I change the date in the components default variant, and also in the hover variant. When I change between the two in editor, the date override sticks. But when I present, the hover variant, resets to the default date text.
Shouldn’t it stick?
Andrew_Chan
Apr 13, 2021 1:38 AM UTC
Hi @Christian_Leon_Christensen - that sounds like a bug. Could you share a file with me via DM? You can make sure I have access by inviting me at achan@figma.com. A video of the bug occurring would also be very helpful so we know where to look. Thank you!
Marc_Nothrop
Apr 28, 2021 1:56 PM UTC
Same issue, although maybe making it complicated for myself – I have a component with 2 states (Active and Inactive), in one variant I want to override the “Label” field to use the same label in both states.
In a separate variant I want the labels to be different between states (in this case deliberately mis-matching the text layer names “Short Label” and “Long Label”.
I create instances of both Variants and apply the text overrides – it all works on the canvas, I can switch back-and-forth between the states on multiple instances and the different button and state labels are retained.
BUT it’s simply not working when I Present the Prototype, with the “Active” state of both Variants switching to the original “Label” placeholder text.
May 4, 2021 4:53 AM UTC
Sure, I’ll do it over the day. Sorry for the late reply, I didn’t get notifications on a reply on email for some reason. Maybe it got caught by the spamfilter.
Emma8
Dec 9, 2021 1:34 AM UTC
Hi @Andrew_Chan I have the same issue. I’m tying to do a simple button with variants and the hover interaction just simply doesn’t work in my prototype it completely dismissed my overrides. Can you guys help ? Thanks a lot!
Jesper_T_Hansen
Mar 31, 2022 1:15 PM UTC
I had the same issue. Renaming the text layer (which had non-sticking overrides) across all variants seems to have fixed it.
Wangui_Kamande
Apr 12, 2022 11:33 AM UTC
I created button component variants (default, hovered, focused). I also added interactions i.e. When a default button is hovered, it becomes the Hovered variant etc.
When I create an instance of the default button, I make it larger than the origina (in the component) is. When I hover, everything changes. The width of the hovered button is smaller. The overrides don’t stick.
Also I have experienced this with literally every component I have made.
[This is very frustrating]
Sebrand_Warren
Dec 8, 2022 7:17 PM UTC
Same issue. Still not addressed. This seems like a pretty simple oversight to fix.
quang_nguyen
Feb 3, 2023 11:43 AM UTC
Hey, I’m still new to Figma and I think we are dealing with the same issue. I’m doing a flip card animation right now.
I first created a variant with the flip animation and it work.
However, when I duplicated it to edit the content (in both the default and flipped states), only the default state’s modifications were shown.
Jul 12, 2023 8:37 AM UTC
Same issue. Any news on this? It has been reportet very often now but seems still unfixed in the new release 😦
Nathan_Brooks
Jul 20, 2023 8:41 PM UTC
I’ve had this same bug for a year now. It use to happen periodically, but now it is consistent. If I have various variants to a parent component, and I change the variant, text, color, or anything to the children components or objects in the other variants of the parent component, then those changes are not reflected in the prototype. They are reflected on canvas when switching between the variants of the parent. This software is becoming unusable from a testing perspective since this bug first occurred.
