Aug 12, 2024 11:07 PM UTC
Variant Modes Not seeming to display in text variant menu
Hey team! So I adapted a pretty cool interactive text box file/tut from Spencer Kelly, but Figma’s variables being as they are, there’s a lot of redundant work that you need to do if you’re going to show a lot of these text fields. Essentially, you need to have duplicated variables for each new text field, otherwise all fields will be edited simultaneously.
In the screenshot above, you can see 4 columns, Input1-Input4. Spencer’s proto was well documented and had only Input1-3, and defined how to add more (Input4, 5, etc.) relatively quickly. The issue is my component is not seeing the new Input4 column.
I have the Figma Professional plan (otherwise my additional modes/columns would be grayed out and limited to one), and have everything else working, ie the three text fields that already had the three columns), so unless I’m double-labeling and misunderstanding modes, can someone explain why I can’t see beyond those three Inputs?
Aug 14, 2024 6:03 PM UTC
Hey @DD12, thanks for reaching out!
This definitely seems odd. Are you able to share your file with us?
If so, please include a link to the file in this topic thread and share edit access with support-share@figma.com, so we can take a closer look.
Gaby_Salinas_L
Oct 3, 2024 5:35 PM UTC
I have the same problem. Did you figure it out? What can I do?
Oct 4, 2024 3:38 PM UTC
Hey @Gaby_Salinas_L,
DD12 never followed up with their file, so we were never able to find a solution to the issue. Are you able to share your file with us?
If so, please include a link to the file in this topic thread and share edit access with support-share@figma.com.
