Jul 11, 2023 10:05 AM UTC
🚨 Variables: Deleted collections and modes don't disappear
When Variables was released I created some collections for testing. Since then I settled on a final version but the old deleted collections still appear in the page/layer selection on the right panel. The same is happening to deleted modes.
djvSolution
Sep 12, 2024 5:30 PM UTC
Hey All, sorry for the continued frustration!
As already mentioned above, our team needs your specific files where this is occurring to allow them to repro and work on the fix.
If you have’t already, you can submit a bug report to our support team directly via the form here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Be sure to use your Figma account email, include a link to the file(s) where this is occurring, and share edit access with support-share@figma.com.
Jim_Knox
Oct 16, 2024 8:53 AM UTC
apparently its a know bug and they are working on it, im having the same problem, I spoke to the PM on Reddit and he said it was W.I.P
neatlyJulian
Oct 22, 2024 5:18 PM UTC
Still not fixed and easy to reproduce:
  1. Turn a file with variable modes into a library
  2. Create other file that makes use of this library (e.g. for colors)
  3. Remove one of the modes of the file in step 1
  4. ¯_(ツ)_/¯
  5. Pain
Jordan_Hughes
Nov 6, 2024 11:06 AM UTC
After lots of experimentation and a number of iterations on a colour system using Variables and Modes I now have lots of orphaned modes supposedly used in a file and being displayed at page level despite the variables no longer existing and not being used/assigned anywhere in the file.
Figma, please clean this up!
Maciej_Balasinski
Nov 6, 2024 5:27 PM UTC
@dvaliao happy to share a file and use case
Nov 6, 2024 11:16 PM UTC
Thanks, @Maciej_Balasinski!
Please include the file link in this thread and share edit access with support-share@figma.com.
If you’re not able to share your file publicly, please share your file with us here: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share edit access with support-share@figma.com, so we can take a closer look.
kasperland
Jan 27, 2025 3:42 PM UTC
I’ve encountered the same issue. Any news on this? ​@dvaliao
Erik Van Lankvelt
Jan 30, 2025 10:24 PM UTC
I’ve encountered this issue as well.  One of our designers deleted variables from a Figma file, but when I use the Figma API (getLocalVariables) to get that file’s variables, it’s still returning the deleted variables.
msllrs
Feb 6, 2025 9:39 PM UTC
its been 84 years
msllrs
Feb 7, 2025 3:00 PM UTC
so, i think i solved it...
first, the easy part:
publish your tokens file with all variables visible (uncheck the hidden ones). then, update the offending library to the latest version of this file.
now, the tedious part:
brace yourself, especially if your component library is large. go through each section, component set, and component. check the modes dropdown at each level. make all hidden layers visible and inspect the selection colors. you'll likely find stray items linked to non-existent variables. if nothing shows in a component's layers, try replacing the frame it's in. sometimes, it's the sections or frames causing issues.
hope that helps!
Bora_Dan1
Feb 13, 2025 8:44 AM UTC
