Fabio_Pia
Sep 11, 2024 10:57 PM UTC
Variables & Conditional Problem
I’m trying to set up a button so that it changes from a disabled to an active state when a certain condition is met. The condition is that at least two components (cards) need to be selected.
Currently, I’ve created two string variables: merge-button-state (with a default value of inactive) and card-state (with a default value of default). On each card, I’ve set an “on click” action to set card-state to “selected”, followed by the condition:
if card-state == "selected"
  set merge-button-state to "active"
This works if I select just one card, but I want the button to become active only when at least two cards are selected.
I’ve also tried creating a variable for each card component, like card1-state and card2-state, but since it’s the same component, this approach doesn’t work.
Any idea how to achieve that?!
Sep 12, 2024 7:46 AM UTC
Hi there,
Thanks for reaching out. I might be misunderstanding, so could you share the current setup with some screenshots? Alternatively, could you provide a link to the file with access granted to support-share@figma.com? This won’t affect your billing. I’m hoping to investigate further.
Toku
