Kajka
Apr 1, 2026 1:16 PM UTC
Using Create figma slides outline (AI) with a custom template
Hello, I have been trying to make this feature work with my custom template, but it seems that no matter what I do and what changes I make to the template, it still comes out wrong. Here are the main issues:
  • every result is different, even when using same materials (texts) and template
  • AI converts random slides to dark mode where it is not supposed to be in dark mode
  • AI uses the Agenda slide as a section header or presentation cover
  • Section header slides are inconsistent, always different
  • AI makes its text + image slide on its own (not from template)
  • AI resizes font sizes of slides it does use from template
I tried:
  • Renaming layers, auto layouts, frames, etc. to their intended purposes
  • Detaching instances from main components (from a different file)
  • Putting all content of a slide into a (renamed) frame to show its purpose
  • Organizing slides based on intention (cover first, then agenda, section slide, etc.)
  • Taking the texts out of auto layout
None of these really worked, there have been some improvements, but still nowhere near to what I need. Is there any way I can make this work,?
