_noha
Jun 27, 2023 6:04 PM UTC
Unframe selection
Wondering if there’s a shortcut to unframing a selection rather than manually moving the components out of the frame and deleting the frame.
There also isn’t an option in the right-click menu to unframe similar to ungroup.
Daniel_Cullinan
Jul 5, 2023 3:09 PM UTC
If you go to the Help and resources question mark icon at bottom right, then Keyboard shortcuts > Selection you can see the shortcut (or set your own) for Ungroup selection
(Note, you cannot ungroup an instance of a component, you first have to use Detach instance)
RizePoint_Product
Jul 5, 2023 3:12 PM UTC
…Are you using the ctrl/cmd + shift + g shortcut on the nested frame or the parent frame? If you use that shortcut on the parent frame it will automatically ungroup and delete the parent frame, leaving its nested children intact.
Otherwise I think you’re going to have to post a video of what you’re trying to do so we can understand, because the problem you’re describing is exactly what the ungroup feature solves.
fernandolins_cs
Jul 5, 2023 3:18 PM UTC
I believe you are using the wrong terminology here. What you’re talking about is breaking variants apart, not unframing. Ungrouping does unframe. Ungrouping does not break apart components and variants, that is why you are not having any success with the shortcut.
  • If you want to break apart component variants, you have to move them out of the component frame
  • If you want to un-component something you have to make a copy of it, detach the copy and delete the original.
  • If you want to break apart a component instance, use the detach command.
_noha
_nohaAuthor
Jul 5, 2023 6:49 PM UTC
I think I finally see what you guys are saying. Maybe I was using the wrong terminology. Appreciate the input!
Feb 4, 2024 10:45 AM UTC
There is no such thing in Figma tool, may you can use the trick; In the pages you can move out the objects from the selective frame and the delete such existed frame from the page or Colum.
