Unable to publish my variables
  • June 29, 2023
  • 19 replies
  • 2222 views
Ezra_Gordon1
I’m getting an error that says “Publishing failed:” when I’m attempting to publish a color palette library.
are there any known issues? is this a known problem?
Screenshot 2023-06-29 at 3.45.37 PM
Best answer by Ryan_52
Hi everyone! We are pleased to inform you that the fix has been successfully released!
Please refresh Figma to ensure that you are using the fixed version.
Brian_Saunders1
I am experiencing the same issue with publishing, and also accessing published variables within files.
Ezra_Gordon1
Thanks for letting me know.
Ezra_Gordon1
I’ve tried the following so far.
  • Restart Figma (did not help)
  • Un-publish library (which failed)
  • Duplicate library then publish (which failed)
Frank_Vasquez1
Same problem here. It doesn’t let me publish my library (just added some variables) neither to update it.
Screenshot 2023-06-29 at 17.19.13
Screenshot 2023-06-29 at 17.20.07
Pierrick_Verilhac
I’m freaking out a little here! Same thing is happening, and it blocks all the downstream variables too (my primitive library won’t publish, and my token library is broken too)
  • June 29, 2023
I’m experiencing this problem as well.
  • June 29, 2023
Hey All,
Sorry to hear you’re having trouble publishing your variables!
Since this can happen for a variety of reasons, please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so our team can take a closer look.
Erin_Roby
  • June 29, 2023
I’m also experiencing this issue. Will put it through community support but still appreciate this thread being created!
  • June 29, 2023
Similar issue, cannot use previously published variables in design files. Logged support request.
Yesterday we had variables (colours) working and testing the feature across our design system with the published collections being used in other Figma files… Today we’re now getting the error ‘An error occurred while retrieving the variable.’ When we try and use a variable colour in another file from the design system… All the colours are just showing as blank / empty palette icons and not displaying their colour and every colour variable gives us the same error… any ideas?
same here… was working ok yesterday - but today we get…
error occurred
Ryan_52
  • Technical Quality Specialist
  • June 30, 2023
Hi everyone, thank you for reporting this issue. Our engineering team is actively investigating the issue to determine its root cause and working towards a solution.
username1
  • June 30, 2023
an error occurred while retrieving variable, my heart just stopped
Ryan_52
  • June 30, 2023
sofie2
  • July 3, 2023
Unfortunately I don’t think it is entirely fixed. I experienced the same issue today, an error that says “Publishing failed:” when I’m attempting to publish update of a color style and typestyle from my library. I have tried looking for Figma updates, restarted Figma, restarted my Mac. Nothing seem to work. I hope you will look into it again.
Akbar_Nurdiansyah
I have a problem when I want to publish the button variable does not appear, does anyone have a solution for this?
Wawa
  • July 20, 2023
Having the same issue here, but I don’t get an error. The variable just aren’t appearing at all.
wllung
  • July 31, 2023
just got this error today, unpublishing the library which decouples all components is not a viable solution
Jack_k
  • August 1, 2023
+1 having issues as well
